Level Numbers
Creates a new column in the data table called Level <colname>. The level number of each observation corresponds to the histogram bar that contains the observation.
Value Ordering
(Use with the Order By option) Creates a new value ordering column property in the data table, reflecting the new order.
Script to Log
Displays the script commands to generate the current report in the log window. Select View > Log to see the log window.
