Note the following about this approach:
• This option can be a good choice for impromptu work. For example, you can manually build the diagram, save it as a journal, then reopen the journal later and continue building and editing the diagram.
• Any customization exists only in the journal, and the journal is not connected to the data table.
To save the diagram as a journal:
1. Highlight the entire diagram.
2. Right-click and select Edit > Journal.
3. Save the new journal.
