Using JMP > JMP Reports > Change the Appearance of Graphs > Scroll and Scale Axes in Graphs
Publication date: 09/28/2021
The hand tool (also known as the grabber tool) (Image shown here) provides a way to change the axes and view of a plot:
On a y-axis, dragging Image shown here scrolls the y-axis; dragging Image shown here or Image shown here scales the y-axis.
On an x-axis, dragging Image shown here scrolls the x-axis; Image shown here or Image shown here scales the x-axis.
Tip: When you drag an axis to change its scale, JMP automatically updates the major and minor tick increments based on the new axis width. To prevent this (retaining your original increments), press Shift while dragging.
You can also right-click in a plot or graph, and select Size/Scale (or Graph > Size/Scale). Choose one of the following options:
To adjust the scale of the X axis, select X Axis. To adjust the scale of the Y axis, select Y Axis or Right Y Axis. For more information about this window, see Customize Axes and Axis Labels in Graphs.
For more information about the Frame Size option, see Specify Graph Size in Pixels.
Select Size to Isometric when the x- and y-axes are measured in the same units and you want distances on the graph to be represented accurately regardless of direction.
