Publication date: 09/28/2021
Stage 2 - Even Order Effect Estimates
The Even Order Effect Estimates report lists second-order effects that are identified as active. Active second-order effects are identified using the guided variable selection procedure or forward selection as described in Stage 2 Methodology. The block effect (if one is included) is also listed, whether it is significant or not.
Figure 8.9 Stage 2 Report
Stage 2 Report
Term
The block factor and second-order effects identified as active.
Estimate
Parameter estimates for a regression fit of Y on the Stage 2 second-order effects defined by Y2nd. See Decomposition of Response.
Std Error
The standard error of the estimate, computed using the Stage 2 RMSE.
t Ratio
The Estimate divided by its Std Error.
Prob>|t|
The p-value computed using the t Ratio and the degrees of freedom for error (DF).
RMSE
The square root of the mean square error that results from the Stage 2 analysis. RMSE is estimated as the residual variance from Y2nd after fitting the second order effects identified as active. See Decomposition of Response.
DF
The degrees of freedom associated with the error estimate used to construct RMSE.
