Design of Experiments Guide > Prospective Sample Size and Power > Reliability Demonstration Calculator > Statistical Details for the Reliability Demonstration Calculator
Publication date: 09/28/2021
The reliability demonstration depends on the assumed failure time distribution with scale parameter σ. The reliability standard, or probability of survival at time t and location μ is stated as follows:
Equation shown here
where μ is solved for using the following:
Equation shown here.
To calculate sample size and the size of the test, the probability of survival at time t is posed as a hypothesis test:
Equation shown here
where p* is the standard probability of survival at time t*.
We want to test the hypothesis at the α level or as follows:
α = Pr(k or few failures | H0 true).
Since the test is of n independent units, the number of failures has a binomial (n, p) distribution where p is the probability of a unit failing before time t. Therefore, we can express α as a function of t and n:
Equation shown here
where μ* and σ* are from the assumed reliability standard.
Properties of the binomial and beta distributions result in being able to solve for t using:
Equation shown here
For n, Brent’s method is used to find the root of:
Equation shown here
where:
B1(α; n k, k + 1) is the α quantile of the Beta(n k; k + 1) distribution
and Φ() is the cumulative distribution function of the assumed failure time distribution.
For more information about calculations in JMP, see Barker (2011, Section 5).
