Publication date: 09/28/2021
Summary of Fit Report
RSquare
Using quantities from the corresponding analysis of variance table, the RSquare for any continuous response fit is calculated as follows:
Equation shown here
RSquare Adj
The RSquare Adj is a ratio of mean squares instead of sums of squares and is calculated as follows:
Equation shown here
The mean square for Error is in the Analysis of Variance report (Figure 5.12). You can compute the mean square for C. Total as the Sum of Squares for C. Total divided by its respective degrees of freedom.
