Many features in this platform are available only in JMP Pro and noted with this icon.
The Text Explorer platform enables you to analyze unstructured text, such as comment fields in surveys or incident reports. Interact with the text data by using tools to combine similar terms, recode misspecified terms, and understand the underlying patterns in your textual data.
The JMP Pro version of the platform contains analysis tools that use singular value decomposition (SVD) to group similar documents into topics. You can cluster text documents or cluster terms that are in a collection of documents. You can also cluster documents using latent class analysis.
The JMP Pro version of the platform also contains tools for identifying important terms and sentiments in your documents. Term selection enables you to identify the terms that best explain different responses. Sentiment analysis enables you to identify sentiment terms in document using lexical analysis and scores documents for positive, negative, and overall sentiment. The Sentiment Analysis feature includes basic natural language processing (NLP) support.
Figure 12.1 SVD Plots in Text Explorer
