Publication date: 09/28/2021
The Fit Response Screening Report
The Fit Response Screening report shows two plots:
The FDR PValue Plot
The FDR LogWorth by Rank Fraction Plot
The FDR PValue Plot is interpreted in the same way as for the platform itself. See The Response Screening Report.
The FDR LogWorth by Rank Fraction plot shows FDR LogWorth values plotted against the ranks of the p-values. The plotted points decrease or remain constant as rank fraction increases. The plot gives an indication of what proportion of tests are significant. An example using the Response Screening personality is given in Response Screening Personality.
Fit Response Screening Options
The Fit Response Screening red triangle menu contains options to save the calculated data.
Model Dialog
Opens a window containing the model dialog that you have run to obtain the given report.
Save Estimates
Opens a data table in which each row corresponds to a response and the columns correspond to the model terms. The entries are the parameter estimates obtained by fitting the specified model. This data table also contains a table variable called Original Data that gives the name of the data table that was used for the analysis. If you specified a By variable, JMP creates an estimates table for each level of the By variable, and the Original Data variable gives the By variable and its level.
Save Prediction Formula
Adds columns to the original data table containing prediction equations for all responses.
Save Least Squares Means
Opens a data table where each row corresponds to a response and a combination of effect settings. The row contains the least squares mean and standard error for that combination of settings.
See Local Data Filters in Reports, Redo Menus in Reports, and Save Script Menus in Reports in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
