When you click Go in the Model Launch control panel, a Model Comparison report appears above the control panel and a model report appears below the control panel. The model reports are numbered sequentially. Each time a new model is fit, it is added to the Model Comparison report and a new model report is added to the window. See Model Comparison Report and Support Vector Machine Model Report. Click on the column headings to sort the models by any of the columns in the Model Comparison report. The first click sorts in ascending order; click the column heading a second time to sort in descending order.
