Publication date: 09/28/2021
Image shown hereWorkspace Options
The Workspace panel supports several right-click commands for adjusting the view of the panel. Here are some of the available commands:
Zoom In
Enables you to zoom in to the system diagram.
Zoom Out
Enables you to zoom out from the system diagram.
Tip: On Windows, you can press Ctrl and use the mouse scroll wheel to zoom in to and out from the diagram.
Zoom Scale
Opens the Set Zoom Scale window enabling you to zoom in or out using a scaling factor. The scaling factor ranges from 0.75 (75%) to 5.0 (500%).
Preview
Enables you to hide or show the Preview window in the Workspace panel.
Align Selected Vertices Vertically
Enables you to align shapes on a vertical line.
Align Selected Vertices Horizontally
Enables you to align shapes on a horizontal line.
Create Series Diagram
Enables you to create a series diagram using the nodes in the diagram. The order of the series is determined by the order of node creation. This option is available only when the diagram does not contain any arrows.
Create Parallel Diagram
Enables you to create a parallel diagram using the nodes in the diagram. This option is available only when the diagram does not contain any arrows.
