Quality and Process Methods > Control Chart Builder > Additional Examples of Control Chart Builder > XBar and S Charts with Varying Subgroup Sizes Example
Publication date: 09/28/2021
This example uses the Coating.jmp data table. This quality characteristic of interest is the Weight 2 column.
1. Select Help > Sample Data Library and open Quality Control/Coating.jmp.
2. Select Analyze > Quality and Process > Control Chart Builder.
3. Drag Weight 2 to the Y role.
4. Drag Sample to the Subgroup role (at bottom).
Figure 3.20 XBar and S Charts for Varying Subgroup SizesĀ
Weight 2 has several missing values in the data, so the chart has uneven limits. Although each sample has the same number of observations, samples 1, 3, 5, and 7 each have a missing value.
Instead of viewing a line connecting the averages of each sample, you can switch to viewing box plots at each sample.
5. In the Points[1] outline, deselect the Show Connected Line option.
6. In the Points[1] outline, select the Box Plots option.
Figure 3.21 XBar and S Chart with Box PlotsĀ
