Using JMP > Get Started with JMP > Platforms and Reports > Analysis Results in Reports
Publication date: 11/29/2021
After you launch your analysis, the JMP report window appears. The report window shows the output of your analysis using interactive graphs and text reports. See JMP Reports.
Figure 2.13 Report Window Features
