Publication date: 11/29/2021
Image shown hereBoosted Tree
Fit Many Layers of Trees, Each Based on the Previous Layer
The Boosted Tree platform is available only in JMP Pro.
Boosting is the process of building a large, additive decision tree by fitting a sequence of smaller decision trees, called layers. The tree at each layer consists of a small number of splits. The tree is fit based on the residuals of the previous layers, which allows each layer to correct the fit for bad fitting data from the previous layers. The final prediction for an observation is the sum of the predictions for that observation over all of the layers.
Figure 6.1 Example of Boosted Tree Layers
Contents
Overview of the Boosted Tree Platform
Example of Boosted Tree with a Categorical Response
Example of Boosted Tree with a Continuous Response
Launch the Boosted Tree Platform
Specification Window
The Boosted Tree Report
Model Validation - Set Summaries
Specifications
Overall Statistics
Cumulative Validation
Boosted Tree Platform Options
Statistical Details for the Boosted Tree Platform
Overfit Penalty
