Publication date: 11/29/2021
Canonical Details
Details for the Test Details Option
When you select the Test Details option for a given test, eigenvalues, canonical correlations, and eigenvectors are shown in the report.
The canonical correlations produced by the Test Details option are computed as follows:
Equation shown here
where λi is the ith eigenvalue of the E-1H matrix used in computing the multivariate test statistics
The matrix labeled Eigvec is the V matrix, which is the matrix of eigenvectors of E-1H for the given test.
Note: The E and H matrices for the given test refer to MEM and MHM in terms of the original E and H matrices. The M matrix is defined by the response design. The E and H used in this section are defined in Multivariate Tests.
Details for Centroid Plot Option
The total sample centroid and centroid values for effects are computed as follows:
Grand = Equation shown here
Effectj = Equation shown here
where
Equation shown here
N is the number of observations
vi is the ith column of V, the eigenvector matrix of E-1H for the given test
Equation shown here is the multivariate least squares mean for the jth effect
Equation shown here is the overall mean of the responses
g is the number of eigenvalues of E-1H greater than 0
r is the rank of the X matrix
The centroid radii for effects are calculated as follows:
Equation shown here
where g is the number of eigenvalues of E-1H greater than 0 and the L matrices in the denominator are from the multivariate least squares means calculations.
Details for the Save Canonical Scores Option
The canonical Y values are calculated as follows:
Equation shown here
where
Y is the matrix of response variables
M is the transpose of the response design matrix
V is the matrix of eigenvectors of E-1H for the given test
Canonical Y values are saved for eigenvectors corresponding to eigenvalues larger than zero.
