Publication date: 11/29/2021
CDF Plot
The CDF plot shows the cumulative distribution function for all of the groups in the Oneway report. CDF plots are useful if you want to compare the distributions of the response across levels of the X factor. The CDF Plot option is not available when a Block variable is specified in the launch window. See Example of a CDF Plot.
