Using JMP > JMP Reports > Change the Appearance of Graphs > Change Line Widths in Graphs
Publication date: 11/29/2021
After fitting a line to a graph, or producing a graph with a line already present, you can adjust the width of the line:
1. Right-click anywhere in a graph.
2. Select Customize.
3. Select Smoother (for example, if the graph contains a smoother).
4. Change the line width. The value is in pixels.
5. Click OK.
