Publication date: 11/29/2021
Choice Script-Only Messages
When you launch the Choice platform via JSL, you can set the acceptable criterion for parameter convergence. In addition, when using Hierarchical Bayes, you can set the number of burn-in iterations.
Convergence Criterion( fraction )
Number of Burn In Iterations ( number)
