Publication date: 11/29/2021
Clustering Script-Only Messages
The following messages for a Hierarchical Cluster object are available only in JSL:
hierarchical_cluster_object << Get Column Names;
hierarchical_cluster_object << Get Clusters;
hierarchical_cluster_object << GetDisplayOrder;
hierarchical_cluster_object << GetColumnDisplayOrder;
hierarchical_cluster_object << Get Distance Matrix;
hierarchical_cluster_object << Standardize( 0|1 );
The following messages for a KDTable object are available only in JSL:
kdtable_object << Distance between rows( row1, row2 );
kdtable_object << Insert rows( number|[ vector ] );
kdtable_object << K nearest rows( stop, <position> );
kdtable_object << Remove rows( number|[ vector ] );
