Publication date: 11/29/2021
Control Limits for XBar and S Charts
JMP generates control limits for XBar and S charts using the following formulas:
LCL for XBar chart = Equation shown here
UCL for XBar chart = Equation shown here
LCL for S chart = Equation shown here
UCL for S chart = Equation shown here
Center line for S chart: By default, the center line for the ith subgroup indicates an estimate of the expected value of si. This value is computed as Equation shown here, where Equation shown here is an estimate of σ.
The estimate for the standard deviation for XBar and S charts is:
Equation shown here
where:
Equation shown here = weighted average of subgroup means
K = the sigma multiplier and is set to 3 by default
σ = process standard deviation
ni = sample size of ith subgroup
c4(n) is the expected value of the standard deviation of n independent normally distributed variables with unit standard deviation
c5(n) is the standard error of the standard deviation of n independent normally distributed variables with unit standard deviation
N is the number of subgroups for which ni ≥ 2
si is the sample standard deviation of the ith subgroup
