Using JMP > Create Formulas in JMP
Publication date: 11/29/2021
Formula Editor
Use the JMP Formula Editor to create a column whose values are computed by a formula and store that formula as part of a column’s information. Formulas can be simple assignments of numeric, character, or row state constants, or they can contain complex evaluations based on conditional clauses. The Formula Editor window operates like a calculator with buttons, displays, and a list of functions.
For more information about the functions that are available in the Formula Editor, see Reference for JMP Functions in Formulas.
Figure 7.1 The Formula Editor
The Formula Editor
Contents
Overview of Formulas
Build Formulas
Refer to Data Table Values in Formulas
Use Local Variables in Formulas
Incorporate Parameters in Formulas
Insert Constants in Formulas
Add Operators to JMP Formulas
Keypad Reference for the Formula Editor
Use Functions in Formulas
Find Frequently Used Functions in the Formula Editor
Copy and Replicate Formulas
Order Expressions in Formulas
Build a Formula in Order of Precedence
JMP Formula Editor Options
Calculate Derivatives of JMP Functions
Simplify Complex Formulas
Evaluate Formulas
Ignore Errors in Formulas
View Formulas in JSL
Edit Formulas
Correct Mistakes in Formulas
Select Expressions in Formulas
Delete Functions Formulas
Cut, Copy, and Paste Formulas
Click and Drag Formulas
Customize Formulas in the JMP Formula Editor
Hide and Show Outlines Formulas
Change the Font Size Formulas
Specify the Matrix Size Formulas
Change the Orientation of a JMP Formula
Open and Close Arguments Formulas
Examples of Building Formulas in the JMP Formula Editor
Use Basic Features in the JMP Formula Editor
Use Local Variables Formulas
Use the Munger Function Formulas
Use the Match Conditional Function Formulas
Use the Delete Expression Button Formulas
Keyboard Shortcuts for the JMP Formula Editor
Glossary of Terms for the JMP Formula Editor
