Publication date: 11/29/2021
Explore Missing Values Script-Only Messages
When you launch Automated Data Imputation through the Explore Missing Values utility via JSL, you can use the following arguments that are available only in JSL:
Maximum Dimension( number )
Validation Portion( number )
The following messages for an Explore Missing Values report are available only in JSL:
explore_missing_values_object << Get U V Sigma ADI Matrices;
