Publication date: 11/29/2021
Explore Outliers Script-Only Messages
When you launch K Nearest Neighbors Outliers through the Explore Outliers utility via JSL, you can use the following arguments that are available only in JSL:
Impute Missing( 0|1 )
The following messages for a Quantile Range Outliers object in Explore Outliers object are available only in JSL:
explore_outliers_obj << Get Quantile Outliers;
explore_outliers_obj << Save Quantile Outlier Limits;
When you launch Robust PCA Outliers through the Explore Outliers utility via JSL, you can use the following arguments that are available only in JSL:
Tolerance( number )
