Publication date: 11/29/2021
Fit Robust
The Fit Robust option reduces the influence of outliers in the response variable. The Huber M-estimation method is used. Huber M-estimation finds parameter estimates that minimize the Huber loss function:
Equation shown here
where
Equation shown here
ei refers to the residuals
The Huber loss function penalizes outliers and increases as a quadratic for small errors and linearly for large errors. In the JMP implementation, k = 2. For more information about robust fitting, see Huber (1973) and Huber and Ronchetti (2009).
