Discovering JMP > Work with Your Data > Get Your Data into JMP
Publication date: 11/29/2021
JMP provides many ways to get your data into JMP.
To copy and paste data from another application, see Copy and Paste Data into a Data Table.
To import data from another application, see Import Data into a Data Table.
To enter data directly into a data table, see Enter Data in a Data Table
You can also import data into JMP from a database. See Import Data from a Database in Using JMP.
This chapter uses sample data tables and sample import data that is installed with JMP. To find these files, see Using Sample Data.
