Using JMP > JMP Preferences
Publication date: 11/29/2021
JMP Preferences
The Preferences Window
JMP preferences enable you to specify general and specific settings and save the settings.
To change preferences
1. Select File > Preferences (Windows) or JMP > Preferences (macOS). The window in Figure 13.1 appears. The previous preferences page that you selected appears.
2. Click a category and make selections. Click Apply to see the results, and then click OK.
Note: When you upgrade to JMP 16 Subscription, changes to preferences are maintained. In other JMP versions, you must customize the preferences after each upgrade.
To search preferences
2. In the Filter box at the top, enter your text.
Text matches are highlighted.
3. Under Preference Group, click a category to see its results.
A search term can show up in these places:
the preference itself
a tooltip for the preference
a list of options for a preference
To reset preferences to the default settings
2. Click Reset All, and then click OK.
Contents
Overview of JMP Preferences
General JMP Preferences
Preferences for JMP Projects
Preferences for JMP Reports
Preferences for JMP Graphs
Style Preferences for JMP Graphs and Reports
Preferences for Data Tables
Preferences for JMP Data Filters
Preferences by JMP Platform
Print Preferences
Preferences for Importing and Exporting Text Files
Preferences for Third-Party Data
Windows Preferences
Mac OS Preferences
Fonts Preferences
Communications Preferences
Preferences for Internet Options
Preferences for File Locations
Preferences for the JSL Script Editor
Preferences for SAS Integration
Preferences for Updating JMP
Preferences for the JSL Debugger
Menu Preferences
Preferences for the Query Builder
Preferences for Recoding Columns
Preferences for the Column Switcher
Preferences for the Log
