The following message for a Latent Class Analysis model fit constructs a script to create probability formula columns and returns them to the log. This message is available only in JSL.
latent_class_analysis_object << ( Fit[number] << Get Probability Formulas );
The following example sets a random seed in order for the model to be reproducible.
dt = Open( "$SAMPLE_DATA/Car Poll.jmp" );
obj = dt << Latent Class Analysis(
Y( :sex, :marital status, :country, :size, :type ),
Set Random Seed( 12345 ),
Number of Clusters( 3 ),
