Basic Analysis > Bivariate Analysis > Launch the Bivariate Platform
Publication date: 11/29/2021
To investigate the relationship between two continuous variables in a bivariate analysis, do the following:
1. Select Analyze > Fit Y by X.
2. Enter a continuous column for Y, Response.
3. Enter a continuous column for X, Factor.
Figure 5.3 The Bivariate Launch Window
The word Bivariate appears above the diagram, to indicate that you are performing a bivariate analysis.
Note: You can also launch a bivariate analysis from the JMP Starter window. Select View > JMP Starter > Basic > Bivariate.
For more information about this launch window, see Introduction to Fit Y by X. For more information about the options in the Select Columns red triangle menu, see Column Filter Menu in Using JMP.
