Basic Analysis > Simulate > Launch the Simulate Window
Publication date: 11/29/2021
Image shown hereLaunch the Simulate Window
To launch the Simulate platform, right-click a column of calculated values in a report window and select Simulate. The Simulate platform is available in many reports, including all reports that support bootstrapping. To use the Simulate platform, the data table must contain a formula with a random component that simulates data.
Note: The Simulate platform is not available in reports that use a By variable.
