When you launch the MaxDiff platform via JSL, you can set the acceptable criterion for parameter convergence. In addition, when using Hierarchical Bayes, you can set the number of burn-in iterations:
Convergence Criterion( fraction );
Number of Burn In Iterations ( number);
