JSL Syntax Reference > JSL Messages > SAS Integration Messages
Publication date: 11/29/2021
Metadata Server Objects
metaserver<<Disconnect()
Description
Disconnects the metadata server.
Returns
Void.
metaserver<<Get Display Name()
Description
Gets the display name of the metadata server.
Returns
A quoted string.
metaserver<<Get Host Name()
Description
Gets the host (machine) name of the metadata server.
Returns
A quoted string.
metaserver<<Get Port()
Description
Gets the port used for the metadata server connection.
Returns
An integer.
metaserver<<Get User Identity()
Description
Gets the identify of the connected user as defined in metadata.
Returns
A quoted string.
metaserver<<Get User Name()
Description
Gets the user name (login ID) that was used for the metadata server connection.
Returns
A quoted string.
