The following messages for a Mixture Profiler object are available only in JSL:
mixture_profiler_object << Contour Value( y1( ... ), y2( ... ), ... );
mixture_profiler_object << Get Constraints;
mixture_profiler_object << Get Factor Settings;
mixture_profiler_object << Get Factor Settings Script;
mixture_profiler_object << Get Simulator;
mixture_profiler_object << Left Factor( column );
mixture_profiler_object << Reset;
mixture_profiler_object << Right Factor( column );
mixture_profiler_object << Term Value( x1( ... ), x2( ... ), ... );
mixture_profiler_object << Top Factor( column );
