The Model Comparison platform is available only in JMP Pro.
The Model Comparison platform in JMP Pro lets you compare the predictive ability of different models. Measures of fit are provided for each model along with overlaid diagnostic plots.
Figure 11.1 Example of Comparing ModelsĀ
