When you launch the Naive Bayes platform via JSL, you can use the following arguments that are available only in JSL:
Prior Bias( fraction )
Use Excluded Rows for Validation( 0|1 )
The following messages for a Naive Bayes object are available only in JSL:
naive_bayes_object << Get Measures;
naive_bayes_object << Get Probability Formulas;
