Publication date: 11/29/2021
Normal Mixtures Script-Only Messages
When you launch the Normal Mixtures platform via JSL, you can use the following arguments that are available only in JSL:
Mixtures N Starts( number )
Mixtures Tolerance( number )
The following messages for a Normal Mixtures object are available only in JSL:
normal_mixtures_object << Get Statistics;
