Using JMP > Customize Menus and Toolbars
Publication date: 11/29/2021
Personalize JMP
This chapter describes how to customize JMP menus and toolbars to show only the commands that you need. For example, you might remove the SAS option in the File menu if you do not use SAS. Or you might assign a shortcut key to the Run Script command.
Customizing JMP also lets you set up JMP for groups with special interests. If one group does not design experiments, you could remove DOE from the JMP menu.
Note: When you upgrade to JMP 16 Subscription, changes to preferences are maintained.
Contents
Customize JMP Toolbars and Menus on Windows
Customize Toolbars
Customize the Main Menu Bar
Create Menu Items and Toolbar Buttons
Set User Permissions for Customized Toolbars and Buttons
Rearrange Toolbars
Copy and Paste Menus, Menu Items, Toolbars, and Buttons
Rearrange Custom Menus, Menu Items, and Buttons
Delete Custom Items
Show or Hide Custom Items
Import Customizations
Remove Customizations from JMP
Customize Toolbars on macOS
Customize Menus on macOS
Customize Menus and Toolbars for Add-Ins
