Publication date: 11/29/2021
Redo Menus in Reports
After performing an analysis, you might want to run the analysis again using different options or variables. You might also want to perform the analysis again if data in the data table have changed. The Redo red triangle menus contain the following options:
Column Switcher
Lets you interactively exchange one column for another on a graph. See Column Switcher.
Redo Analysis
Duplicates the analysis based on the previous launch window settings. The analysis appears in a new report window. This option is helpful if the data have changed.
Relaunch Analysis
Opens the launch window and recalls the settings used to create the report.
Automatic Recalc
Automatically updates analyses and graphics when data table values change. See Automatic Recalc.
