Publication date: 11/29/2021
Run Chart Example
Run charts display a column of data as a connected series of points. This example is a Run chart for the Close variable from Stock Averages.jmp.
1. Select Help > Sample Data Library and open Stock Averages.jmp.
2. Select Analyze > Quality and Process > Control Chart > Run Chart.
3. Select Close and click Y.
4. Click OK.
Figure 3.22 Run Chart for Stock Averages Closing PriceĀ
