Design of Experiments Guide > Sample Size Explorers > Saved Settings in the Sample Size Explorers
Publication date: 11/29/2021
The Saved Settings report provides a table of saved settings enabling you to compare study scenarios. Each time you click the Save Settings button, a new row is added to the table. Click on a row in the table to reset the explorer to those settings. Right-click in the table and select Columns to display additional parameter values in the table.
The Saved Settings red triangle contains the following options:
Clear Selected Rows
Removes the selected rows from the Saved Settings table.
Clear All
Clears all rows from the Saved Setting table.
Make Table
Creates a new a data table that contains all Saved Settings table columns including those that are hidden.
