Publication date: 11/29/2021
Image shown hereStatistical Details for Estimation Methods
Penalized regression methods introduce bias to the regression coefficients by penalizing them.
Image shown hereRidge Regression
An l2 penalty is applied to the regression coefficients during ridge regression. Ridge regression coefficient estimates are defined as follows:
Equation shown here,
where Equation shown here is the l2 penalty, λ is the tuning parameter, N is the number of rows, and p is the number of variables.
Image shown hereDantzig Selector
An l penalty is applied to the regression coefficients during Dantzig Selector. Coefficient estimates for the Dantzig Selector satisfy the following criterion:
Equation shown here
where Equation shown here denotes the l norm, which is the maximum absolute value of the components of the vector v.
Image shown hereLasso Regression
An l1 penalty is applied to the regression coefficients during Lasso. Coefficient estimates for the Lasso are defined as follows:
where Equation shown here is the l1 penalty, λ is the tuning parameter, N is the number of rows, and p is the number of variables
Image shown hereElastic Net
The Elastic Net combines both l1 and l2 penalties. Coefficient estimates for the Elastic Net are defined as follows:
This is the notation used in the equation:
α is a parameter that determines the mix of the l1 and l2 penalties
Tip: There are two sample scripts that illustrate the shrinkage effect of varying α and λ in the Elastic Net for a single predictor. Select Help > Sample Data, click Open the Sample Scripts Directory, and select demoElasticNetAlphaLambda.jsl or demoElasticNetAlphaLambda2.jsl. Each script contains a description of how to use it and what it illustrates.
Image shown hereAdaptive Methods
The adaptive Lasso method uses weighted penalties to provide consistent estimates of coefficients. The weighted form of the l1 penalty is defined as follows:
Equation shown here
where Equation shown here is the MLE when the MLE exists. If the MLE does not exist and the response distribution is normal, estimation is done using least squares and Equation shown here is the solution obtained using a generalized inverse. If the response distribution is not normal, Equation shown here is the ridge solution.
For the adaptive Lasso, this weighted form of the l1 penalty is used in determining the Equation shown here coefficients.
The adaptive Elastic Net uses this weighted form of the l1 penalty and also imposes a weighted form of the l2 penalty. The weighted form of the l2 penalty for the adaptive Elastic Net is defined as follows:
Equation shown here
