Design of Experiments Guide > Prospective Sample Size and Power > Reliability Test Plan Calculator > Statistical Details for the Reliability Test Plan Calculator
Publication date: 11/29/2021
The reliability test plan is designed to estimate either a quantile:
Equation shown here
or a failure probability:
Equation shown here
at a specified level of significance with an assumed failure time distribution and precision measure. Φ() is the standard cumulative distribution function of the assumed failure time distribution with location parameter μ and scale parameter σ. Wald confidence intervals and the precision measure define precision as a function of t (time) and n (sample size). Numerical methods are used to solve for the desired quantity.
For more information about calculations in JMP, see Barker (2011, Section 6).
