Publication date: 11/29/2021
Survival Platform Options
The Product-Limit Survival Fit red triangle menu contains the following options:
Survival Plot
Shows the overlaid survival plots for each group.
Failure Plot
Shows the overlaid failure plots (proportion failing over time) for each group (in the tradition of the reliability literature.) A failure plot reverses the vertical axis to show the number of failures rather than the number of survivors.
Note: The Failure Plot option replaces the Reverse Y Axis option found in older versions of JMP (which is still available in scripts).
Plot Options
Contains the following options:
Note: The first seven options (Show Points, Show Kaplan Meier, Show Combined, Show Confid Interval, Show Simultaneous CI, Show Shaded Pointwise CI, and Show Shaded Simultaneous CI) and the last two options (Fitted Survival CI, Fitted Failure CI) pertain to the initial survival plot and failure plot. The other five (Midstep Quantile Points, Connect Quantile Points, Fitted Quantile, Fitted Quantile CI Lines, Fitted Quantile CI Shaded) pertain only to the distributional plots.
Show Points
Shows the sample points at each step of the survival plot. Failures appear at the bottom of the steps, and censorings are indicated by points above the steps.
Show Kaplan Meier
Shows the Kaplan-Meier curves. This option is on by default.
Show Combined
Shows the survival curve for the combined groups in the Survival Plot.
Shows the pointwise 95% confidence bands on the survival plot for groups and for the combined plot when it appears with the Show Combined option.
Show Points, Show Combined
When you select the Show Points and Show Combined options, the survival plot for the total or combined sample appears as a gray line. The points also appear at the plot steps of each group.
Shows the simultaneous confidence bands for all groups on the plot. Meeker and Escobar (1998, ch. 3) discuss pointwise and simultaneous confidence intervals and the motivation for simultaneous confidence intervals in survival analysis.
Changes the plotting positions to use the modified Kaplan-Meier plotting positions. These plotting positions are equivalent to taking mid-step positions of the Kaplan-Meier curve, rather than the bottom-of-step positions. This option is recommended, so it is on by default.
Shows the lines in the plot. This option is on by default.
Fitted Quantile
Shows the straight-line fit on the fitted Weibull, lognormal, or exponential plot. This option is on by default.
Shows the 95% confidence bands for the fitted Weibull, lognormal, or exponential plot.
Shows the display of the 95% confidence bands for a fit as a shaded area or dashed lines.
Fitted Survival CI
Shows the confidence intervals (on the survival plot) of the fitted distribution.
Fitted Failure CI
Shows the confidence intervals (on the failure plot) of the fitted distribution.
Exponential Plot
Plots the cumulative exponential failure probability by time for each group. Lines that are approximately linear empirically indicate the appropriateness of using an exponential model for further analysis. For example, in Figure 13.5, the lines for Group 1 and Group 2 in the Exponential Plot are curved rather than straight. This indicates that the exponential distribution is not appropriate for this data. See Exponential, Weibull, and Lognormal Plots and Fits.
Exponential Fit
Produces the Exponential Parameters table and the linear fit to the exponential cumulative distribution function in the Exponential Plot (Figure 13.5). The parameter Theta corresponds to the mean failure time. See Exponential, Weibull, and Lognormal Plots and Fits.
Weibull Plot
Plots the cumulative Weibull failure probability by log(time) for each group. A Weibull plot that has approximately parallel and straight lines indicates a Weibull survival distribution model might be appropriate to use for further analysis. See Exponential, Weibull, and Lognormal Plots and Fits.
Weibull Fit
Produces the linear fit to the Weibull cumulative distribution function in the Weibull plot and two popular forms of Weibull estimates. These estimates are shown in the Extreme-value Parameter Estimates table and the Weibull Parameter Estimates tables (Figure 13.5). The Alpha parameter is the 0.632 quantile of the failure-time distribution. The Extreme-value table shows a different parameterization of the same fit, where Lambda = ln(Alpha) and Delta = 1/Beta. See Exponential, Weibull, and Lognormal Plots and Fits.
LogNormal Plot
Plots the cumulative lognormal failure probability by log(time) for each group. A lognormal plot that has approximately parallel and straight lines indicates a lognormal distribution is appropriate to use for further analysis. See Exponential, Weibull, and Lognormal Plots and Fits.
LogNormal Fit
Produces the linear fit to the lognormal cumulative distribution function in the lognormal plot and the LogNormal Parameter Estimates table shown in Figure 13.5. Mu and Sigma correspond to the mean and standard deviation of a normally distributed natural logarithm of the time variable. See Exponential, Weibull, and Lognormal Plots and Fits.
Fitted Distribution Plots
Use in conjunction with the fit options to show three plots corresponding to the fitted distributions: Survival, Density, and Hazard. If you have not performed a fit, no plot appears. See Fitted Distribution Plots.
Competing Causes
Performs an estimation of the Weibull model using the specified causes to indicate a failure event and other causes to indicate censoring. The fitted distribution appears as a dashed line in the Survival Plot. See Competing Causes.
Estimate Survival Probability
Estimates survival probabilities for the time values that you specify.
Estimate Time Quantile
Estimates a time quantile for each survival probability that you specify.
Save Estimates
Creates a data table containing survival and failure estimates, along with confidence intervals, and other distribution statistics.
