Basic Analysis > Contingency Analysis > Correspondence Analysis > Understanding Correspondence Analysis Plots
Publication date: 11/29/2021
The row profile can be defined as the set of row-wise rates, or in other words, the counts in a row divided by the total count for that row. If two rows have very similar row profiles, their points in the correspondence analysis plot are close together. Squared distances between row points are approximately proportional to Chi-square distances that test the homogeneity between the pair of rows.
Column and row profiles are alike because the problem is defined symmetrically. The distance between a row point and a column point has no meaning. However, the directions of columns and rows from the origin are meaningful, and the relationships help interpret the plot.
