Using JMP > JMP Reports > Use Markers in Graphs
Publication date: 11/29/2021
Markers are points on a graph that represent data. Once they are changed from their default setting, they also appear next to rows in the data table.
Change the Shape of Markers
Change the Color of Markers
Change the Size of Markers
Work with Crowded Markers
Add Outlines Around Markers
Change the Selection Mode of Markers
Specify the Transparency of Markers
Exclude and Hide Markers
Use Images as Markers
Change the Shape or Color of Markers Based On Values
