Publication date: 11/29/2021
Work with Control Limits
Control limits are based on the performance of your process and tell you about the variability in your process. Upper control limits (UCLs), center lines, and lower control limits (LCLs) are calculated from the data when a control chart is created. You can use these calculated control limits to indicate when your process has changed.
It is important to note that control limits are different from specification limits, which are often used in capability analysis.
Table 3.9 Control Limits versus Specification Limits
Control Limits
Calculated from data
Defined by the customer or design
Based on variability
Based on system requirements
The voice of the process
The voice of the customer
