Publication date: 11/10/2021
Contour Profiler Script-Only Messages
The following messages for a Contour Profiler object are available only in JSL:
contour_profile_object << Contour Value( y1( ... ), y2( ... ), ... );
contour_profile_object << Get Constraints;
contour_profile_object << Get Factor Settings;
contour_profile_object << Get Factor Settings Script;
contour_profile_object << Get Simulator;
contour_profile_object << Horizontal Factor( column );
contour_profile_object << Number of Plots Across( number );
contour_profile_object << Reset;
contour_profile_object << Term Value( x1( number ), x2( number ), ... );
contour_profile_object << Vertical Factor( column );
contour_profile_object << Y Colors( color1, color2, ... );
