Publication date: 11/10/2021
Distribution Script-Only Messages
The following message for a Distribution object is available only in JSL. The message creates an array of handles to the fitted distributions, so you can send commands to specific distributions:
dist_object << ( Fit Handle[n] << ...);
You can also get a reference to a fitted distribution directly if you send the Fit Distribution message to a Distribution object. This enables you to send commands to specific distributions:
fit_object = dist_object << Fit Distribution( distribution_name );
fit_object << ...;
The following message for a Distribution object is available only in JSL. The message specifies that PpK labeling be used in the Process Capability reports within the Distribution report object.
dist_object << PpK Capability Labeling( 1 );
The following message for a Distribution object is available only in JSL:
dist_object << Outlier Box Plot Row Cutoff( number );
The following messages for a Distribution object use the name of a fitted distribution, such as Fit Lognormal, and they are available only in JSL:
dist_object << Fit Distribution Name( Process Capability( Set Proabilities for Quantile Spec Limits( ... ) );
dist_object << Fit Distribution Name( Process Capability( Set Sigma Multiplier for Quantile Spec Limits( ... ) );
