Publication date: 11/10/2021
OC Curves for Control Chart Options
For control charts, you can use OC curves to explore how chart parameter settings impact β, which is the probability of failing to detect a specified shift of interest. Use the text boxes, sliders, or the LCL, Shift, and UCL handles on the OC curve to set and adjust chart parameters. The chart parameters are as follows:
Lower Control Limit
Specifies the lower control limit from your control chart.
Upper Control Limit
Specifics the upper control limit from your control chart.
Sample Size
(Not available for C charts.) Specifies the sample size used for your control chart measure.
Sigma
(Available only for XBar charts.) Specifies your control chart sigma.
Shift
Specifies the shift to detect.
Beta
Specifies the probability of failing to detect the specified shift given the control chart specifications. Beta updates as the specifications are changed.
