Essential Graphing > Graph Builder > Right-Click Menus
Publication date: 11/10/2021
Right-Click Menus
Numerous options are contained in Graph Builder right-click menus. The specific menu options depend on where in a graph you click, and the types and number of variables in your graph. Descriptions for the right click menu options are grouped in the following categories.
Graph Options
Grouping Zones Options
Options for Columns in the Variables Panel
Options for Axes, Axes Variable Labels, or Graph Titles
Options for the Dividing Line between Multiple Graphs
Legend Options
For multiple graphs (created with grouping zones or the Wrap zone), note the following:
Generally, any options that you apply to one graph element apply to all graphs, across all grouping and wrap variables.
To apply an option to only one graph, right-click in that graph area and select the option from the Graph menu.
To apply an option to all of your multiple graphs simultaneously, first hold down the Ctrl key and right-click and then select the option from the Graph menu.
