Using JMP > Save and Share Your Data > Save a Log Window
Publication date: 11/10/2021
Save a Log Window
Selecting View > Log displays a window that monitors JMP activities, such as JSL statements as they execute and script errors. You might also encounter instances where running a formula, matrix, or another operation writes information of interest to the log window.
To save a log, follow these steps:
1. Open the Log window.
2. Select File > Save As.
3. (Windows only) To open the log automatically when text is added to it, select File > Preferences > Windows Specific. In the Open the JMP Log window list, select whenever text is added.
