Using JMP > JMP Reports > Navigate JMP Reports > Combine Several JMP Reports
Publication date: 06/21/2023
Suppose that you perform multiple analyses and want to show all of the results (and the data table) in one window. You can select and combine the reports and the data table in several ways. See Example of Combining Windows to Create a Dashboard.
